Crimson 3 Popups
wdd0422
Nov 2003
100
I'm doing my first project with Crimson 3. Can someone tell me how to do Popup windows for alarms so that it doesn't my current page.
Bill
I have never used pop ups in my programs. I just put an Alarm Ticker at the top of my Master Slide. I set it up so that when you touch the top of the screen, you go to the Alarm Log page.
Here is an example I got from OkiPC. He has a lot of things in this DB that might help you out. It helped me.
(y)
If you tell what devices you'll be using and a rough outline of the application, there are quite a few examples out there you can build from.
Paul
Yes, that would work as well and would be an option. I like to use popups though if possible. I have a Fanuc robot, molding machine, vision system to check parts, also do a vacuum test a feeder bowl with a pick and place to position the parts for the EOAT pick up. I want to alarm if certain sensors don't make. I'd also like to use a username or password to clear some of the alarms so that I know it has been brought to the attention of the right people and be able to log it, for instance with quality issues.
Actually I have to admit the example is much better then what I had in mind, may be beyond my ability at this point though
Scenario: I have a set of tags I would like to edit with a modal popup window. I want the user to only enter a SP within a certain range of it's...
1,646
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
115
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
191
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
107
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
91
