RSLinx as a service
S0lrac
Jun 2011
Aguascalientes
I can't start RSLinx as a service, any ideas?
I use the RSlinx Launch control panel to try run it, but it doesn´t work, i only can use it as an aplication. :unsure:
I already re-install it to check if there was a problem with an archive related to RSLinx, but it didn't work either.
I was thinking the same thing Daba. If he doesn't have admin rights then someone with admin rights will have to be the one to log in and configure it to run as a service. Once an admin configures it then it should run as a service for a non-admin.
Is this by any chance on Windows 2003 server? There is an issue with RSLinx disappearing out of the services list for that OS. I believe there is a tech note on it in the Rockwell KB. I believe it involves deleting a registry key. I'm not at work right now, but if you can confirm your OS, I will try to find the solution and post it for you when I'm back at work tomorrow.
Jeff
The version i have is RSLinx Classic and i do have administrator rights :unsure:
That helps some, however, to make it complete, we also need the version number of RSLinx Classic. i.e. 2.57. There are some AB Knowledge articles that may be of assistance.
As asked by Jeff above, also give us your Operating System and Service Pack, as that may affect the answer as well.
Stu....
Stu....
I have windows XP
Finally got it, turns out that i had to unistall it, and then delete the folder that remains in the rockwell software folder, then delete all the register related to RSLinx with the Register editor. Before i do that i just install it again and RSLinx is ready to use it as a server again 🍻
Thx to all for the tips and responses.
Hey Folks, I am facing an issue with rslinx classic (gateway) , wherein the "always run in service mode" checkbox does not appear on the...
1,220
Hey all, I've just set up our new laptop with RSLinx, but I cannot get it to work as a service. When I run the RSLinx Launch Control Panel, I...
5,856
We have a vm running factorytalk se on that we have rslinx so factorytalk can talk to a slc 500. When we loose power to the plants we have to...
2,089
Hi, I am using RSLinx Classic V 2.59 running on Windows XP Professional SP2. I am using OPC Test client to connect to RSLInx OPC Server but :-...
4,213
I just installed rslinx oem. I used to have lite. We got OEM so that we can send data to an OPC. I want to run linx as a service but I cant...
4,089
