All,
I am having an odd parameter issue with an IT6 module that I cant figure out.
My set up: L33ER, OB16, OA16, IQ16, IQ16, PB4, IT6, IF8 on the base PLC in one cabinet.
In another cabinet I have: AENTR, IA16, OB16, IT6, HSC, P4B, IF8.
My issue is with the IT6 module on the same rack with the AENTR. Every so often (seemingly random) the IT6 module will fault, the fault being, "(Code 16#0009) Module Configuration Rejected: Parameter Error. Additional Fault Code 16#0401". It has never gone more than a day or two without faulting and sometimes it has run as little as 2 or 3 hours be fore going tango uniform.
I am not actively changing any parameters the PLC when it happens. I have at least 4 other PLCs in the plant with IT6's on including one in this current setup that have not experienced this issue. I've tried Engineering 1x, Engineering 10x, and Raw/Proportional Data Formats for it with the same results. To my knowledge I have set this card up the same way I have done all the others. The machine has been up and running for about a 2 weeks now. Anyone out there have any experience with this issue that can shed some light on the problem?
My solution right now is to wait until they are finished running for the day and cycle power to clear the faulted module. A side question I have is is there any way to clear a faulted module without power cycling? The "Clear faults" option is grayed out when i try it.
Thanks in Advance,
Luke
Thanks in Advance,
Luke
