View Single Post
Old December 6th, 2002, 07:08 PM   #6
United States
tomneth is offline
And this is where a question comes up as to grounding/shielding. I recently installed some 120 VAC transformers to run some heaters. Our plant requires us to ground the neutral at the transformer. We were also told to run a ground wire from the casing to the grounding bar inside the cabinet. This grounding bar also has some shield wires attached from analog input signals. Is this a good practice or would I be better off with a seperate 'shield' bar for the shield wires even though it would be attached to the grounding bar?
