View Single Post
Old November 28th, 2017, 09:45 PM   #1
kalabdel
Canada
kalabdel is offline
What are:Single-Rotation and Pole-Changing motors?
Hello everyone,
In the attached motor wiring there are three different types of motors shown, being: 1-Single-rotation motors, Pole-Changing motors and Dual-Voltage motors. Dual voltage I understand, the other two I don't.
Single rotation means I can not change the motor direction of rotation by switching two of the phases?
Also in the wrining shwon isn't the single-rotaion motor also dual voltage Wye and Delta?
Pole-Changing changes the motor speed? How does that work?
Edit:
One more question, what is temperature monitoring or rather how is it implemented in the motor? There's a small terminal block in the junction box that is marked R1 and R2 where do they connect to inside the motor and how are they used in c control circuit?
Kal
