Excel code for breaking values into bit fields
sparky_289
Jun 2008
Hilmar
I'm looking for a fast easy Excel code to move whole integer values into separate bit fields. Does anyone know of a relatively easy code?🔨
This formula should work:
=MID(TEXT(DEC2BIN(123,8),"00000000"),X,1)
where 123 is the number (could be reference to another cell) and in this case 8 is the number of bits you're working with. X is the position of the binary digit you want to extract (counting from the left/MSB, not the right). In order for the DEC2BIN function to work, you need to have the Analysis Toolpak enabled.
The attached spreadsheet has a little bit of legerdemain in it in the form of a custom function in VBA.
The function is:
Public Function BITAND(x As Long, y As Long)
BITAND = x And y
End Function
and it is located in Module 1 on the VBA sheets. You will need to have Excel security set to allow macros - I recommend medium so that you get a prompt before opening.
With the custom function any integer can be bitwise ANDed with any other. By ANDing it with 2^n, where n is a bit position, we can determine if that bit is TRUE or FALSE, and return the value 1 or 0 with the Excel IF function.
Just another way of doing it without using TEXT functions. It handles unsigned integers.
Also there is a useful tool called LL-SOLVER that is a free download, you can get it from the dowload section at MRPLC, which is useful for converting and viewing 16 bit integers in hex, decimal, and binary - much simpler than EXCEL for the occasional quick binary conversion.
http://forums.mrplc.com/index.php?download=606
A different approach - no vba
abcdefghijklmnopq1bit151413121110987654321023276816384819240962048102451225612864321684213111111111111111111111111878787872323773104=if(b6=1,a3-b2,a3)56=c3,1,0)">0=d3,1,0)">0=e3,1,0)">0=f3,1,0)">0=g3,1,0)">0=h3,1,0)">1=i3,1,0)">0=j3,1,0)">0=k3,1,0)">0=l3,1,0)">1=m3,1,0)">0=n3,1,0)">1=o3,1,0)">0=p3,1,0)">1=q3,1,0)">1=r3,1,0)">17=b2,1,0)">=if(a3>=b2,1,0)
formula listed below the start of cell/row so visible in this copy. Formulas copied across b3 thru q3 and b6 thru q3. Number to parse goes in a3, row 6 gives bits. Formulas could probably be combined and row 2 numbers hardcoded into formula if you need to get to one line.
Mike
And this is my code which I use for a long time.
Code:
Function KM(ByVal H As Long, L As Long) As String
' this function returns binary sequence as string
' H - input integer value
' L - length of returned string
Dim k As Long
Dim E As Long
KM = "B"
1:
    E = H Mod 2
        If E = 0 Then
            KM = "0" + KM
        Else
            KM = "1" + KM
        End If
    H = Int(CDbl(H) / 2)
    If H >= 1 Then GoTo 1
k = 1 + L - Len(KM)
While k <> 0
KM = "0" + KM
k = k - 1
Wend
End Function
I was late a little, but I will be glad if it be useful for someone.
Some more skinned cats
I normally use the ^ (power of) operator when decoding binary to/from decimal. There are three functions on the sheet, Decimal to binary,Binary to decimal and a function to check a bit status in a word.
Hello friends; I found a code for VBA use in excel to read the Tags values from RSlogix 5000 through RSlink. The code is here: Dim OPCServer1 As...
3,775
Hi, I use Excel to write some routines and was wondering if it is possible to add rung comments when doing so? Excel function: ="MOV "&[@[Range...
2,547
I need to create and write an Excel Application using VBA code using Factory Talk View 7.0. Thanks a lot.
2,604
I am using rslinx to populate row 2 of a Excel sheet. I have a macro that will copy the real time data from row 2 and insert a new row below and...
16
5,670
I am trying to get a digital output based on a barcode read. The scan talks to an IBM AS400 where it is verified as good or bad, if it is a bad...
5,244
