How to change HMI page with selector switch
Paradigm1999
Sep 2011
Asia
I am using Siemens S7-300 PLC and a Comfort panel HMI. I had 2 pages on my HMI. One is the Overview page and the other is the automatic page.
I had a selector switch connected to DI0 and DI1 of my PLC. I wanted to change the page of the HMI when the selector switch is changed. When DI0 set and DI1 reset, Overview page comes out. When DI0 reset and DI1 set, change to Automatic page on the HMI.
Can someone tell me what function or logic I can used to command the HMI to change page when DI0 or DI1 is set. Thanks a lot for your help
Code:
A "DI0"    // If selection 1
AN "DI1"
JCN AUTO
L 1        // Select screen number 1
T "ScreenNr"
AUTO: AN "DI0"   // else if Selection 2
A "DI1"
JCN NSEL
L 2              // Select screen number 2
T "ScreenNr"
NSEL: NOP 0      // Else do nothing
In WinCC, create tag linking to "SceenNr".
In the properties of this tag: Events > Change value > ActivateScreenByNumber. Screen number = "ScreenNr"
Now make sure your screens in WinCC have the correct numbers.
General > Settings > Number.
1 for Overview, 2 for Automatic screen.
Hi jeebs, sorry to let u know I am using TIA portal but very new to it and also Siemens programming. Am using omron all this while. How to do that in TIA portal
Hi Jeebs and STL, I still dont get it. Do I create the tag in the PLC tag or HMI tag? How to link them together? Hi STL, can show the full screen shots of your TIA portal? Thanks a lot
Hi Jeebs and STL, I manage to setup the iScreenNr on the HMI tag linking the > Change value > ActivateScreenByNumber. Screen number = "iScreenNr"
However, where do I enter the code?
I tried to create a Function Block DB with STL language but DI0.0, DI0.1, iScreenNr are all highlighted in red. How can I assign the iScreenNr to my HMI iScreenNr?
Hi Jeebs and STL,
Is this the correct way to link the PLC and HMI tag together so that when the PLC pass value to the HMI, it will update the screen? Thanks a lot
Was kinda busy, last days of the year people just need to have thing happen asap.
I haven't had the pleasure of using TIA portal yet, but it does look correct to me.
I have a Red Lion G09 scanning 8 Invertek P2 VFDs via modbus RTU - I've setup necessary comms and tags and all works well. I have a 'Settings'...
1,838
I have Beijer E1022 HMI and I noticed recently change in real time. I corrected the time. Anyone got idea about the reason for change in time
1,691
Hello, I am currently trying to control a motor in my plc. I've made a simple on/off button logic. And it works pretty well, when i press the...
25
5,898
Hello guys, I use Tia Portal V16. What is the best way to change the indexed HMI tags when I change the format of an Udt in my plc program...
1,298
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,133
