FactoryTalk View Studio for Machine Edition "Unable to Install"
abyvarghes
Mar 2016
Adelaide
Hi All,
I am trying to install FT View Machine Edition in to one of the computer. But not successful yet. Kindly have a look the log I am getting below. Please let me know if you need the full log file. But I could successfully installed in to VM Machine, this is a normal computer that connects to the domain. Even I tried to install as domain administrator. Still gets the same error. Please see the attached full log file.
FactoryTalk View Setup: End feature lookup for
FactoryTalk View Setup: Begin calling plugin [FTViewSetupPlugin.dll] during stage [PreInstall]
FactoryTalk View Setup: Turning execution over to FTViewSetupPlugin.dll now.
Setup Plugin: Begining to Create FTView Database user...
Setup Plugin: Creating ADO connection instance...
Setup Plugin: Creating ADO connection instance is successful.
Setup Plugin: Checking if the FTView default user is qualified...
Setup Plugin: The FTView default user is not qualified, will be created.
Setup Plugin: Connecting to the databse...
Setup Plugin: Checking if the defaule FTView user is exist...
Setup Plugin: The defaule FTView user is not exist.
Setup Plugin: The defaule FTView user is being create...
Setup Plugin: Creatting is successful.
Setup Plugin: Resetting account status...
FactoryTalk View Setup: Taking execution back from FTViewSetupPlugin.dll now (Plugin threw an exception)
FactoryTalk View Setup: End calling plugin [FTViewSetupPlugin.dll] during stage [PreInstall]
Setup Plugin: Run RecoverDistributed() after running VSClean.exe.
Thanks,
Aby Varghese
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
132
Hi all, I'm having an issue with connecting View Studio emulation to a real PLC. I am running View Studio 8.01 on a Hyper-V virtual machine...
260
Hello. I have a Project I'm doing in Factorytalk View Studio. One of my displays I created has a bunch of red x's on all of the objects I created...
690
So, I'm new to the PLC world (fresh graduate) and at my job I've been pretty much only helping out the other programmers with simpler tasks while...
625
Good morning, I have a project coming up that will require my HMI runtime to toggle from English to Spanish via selector switch. What is the...
459
