unstable redundant controlnet communication for controllogix
Jul 2007
cairo
hi all
i'm working at controllogix with rsview me using controlnet communication,i have problem for redancy that give me pri and the other indicate disq some times and some times give me right indication for pri&syn that my system node
  • 1 sync controllogix processor
  • 1 pri controllogix processor
  • 1 chassis I/O module
  • 1 pc for rsview me scada
is that node enough for redundant system for controllogix processor
and if that's enough plaese advice for my problem
Node don't have to be scheduled nodes, you needs any 2 nodes in addition to your primary and secondary. these nodes must have node number less than your redundand nodes.
In any case node count and numbering can cause delay in switchover (bump) but not the disqualification you see.
Read SRM logs - they should tell you what happening.
It takes a minute or two just to open, I think this is from the license checks. After it is open it takes like 5-10 minutes to upload a 2.5MB...
1,207
Hello all! I am trying to figure out how to tune PIDE for an unstable heater. This is a startup tuning. My project was to remove old temp...
3,249
I'm fairly new to the world of PLC's. So far I've managed to resolve the problems I've crossed but this one has me stumped. I've got a Rotork...
3,861
Hi, I am doing I/O testing on a new installation. My Kiesselmann valves on ASi are not opening when I give the open command. I can see from the...
1,792
Dearall, I am using a Delta SS2 PLC with 6xa analog card, [ TO K0 K1 H480 K1] using first two analog inputs ans 0~10 v dc input and rest of the...
1,866
