Siemens screen to GE PLC
Msut419
Feb 2018
new york
This is an odd one all, I have GE 90/70 PLCs and a very old version of Cimplicity (6.1) to control them with. We have recently add a new machine in my plant and the controls are all new state of the art and i have Siemens screens one it, they work great and are a cheaper solution to GE upgrade.
So my question is, can I use these screens with my GE 90/70 PLCs without doing anything crazy? Does the Siemens screen have a protocol converter built in? (I do not want to use a redlion)
What Siemens screen do you have?
Not familiar with the PLC you mention, what protocols does it support? Modbus might be an option?
The 90/70 is talking over TCP/IP but i can't find if it is talking mudbus or not. I does say that it talks over SRTP.
SRTP is GE's serial SNP protocol adapted for Ethernet TCP/IP. The 90-70 only ever supported SNP through the serial port on the CPU module and SRTP through the Ethernet module.
To use Modbus RTU you would need a communications coprocessor module IC697CMM711.
Or else check your documentation of the Siemens HMI to see if it supports communication with GE PLCs using SNP or SRTP.
Context: PLC= S7-1212C, HMI=KTP1200 Basic. Hi again, When the "REPORT" button is pressed (on a different screen), it takes the operator to the...
659
Hi, Can anyone help me on this? I want to implement a "screen lock" (HMI is KTP1200 Basic). e.g. if the person who's logged in, leaves the...
665
Hi, I have a HMI which is a KTP1200 Basic. Let's suppose USER03 is logged in. How do I create a simple "Lock Screen" that appears if the screen...
670
I've got TIA portal v18, KTP1200 HMI. I want to add a slider bar (if that's the correct name for it) to an HMI screen. Baslcally, like a...
1,097
See the attached pic ("workflow"). I want to create 2 workflows, depending on if the person who's just logged in is an OPERATOR or an ADMIN...
17
2,469
