12 V PLC suitable for automotive use?
ROAMER_AUS
Jul 2014
Umag
50
Can anyone recommend 12V PLC , to be used in a car. That is robust and can handle variations in normal car voltage?
Bit on a budget side to :)
Try automationdirect.com They used to have one, don't know if they still do. Several years back they used to sponsor a NASCAR race car in that drek that passes for racing in the US. IIRC they used a PLC in the car. I can't imagine for what, except advertising.
How about an Arduino or RaspberryPi? If you're committed to a PLC type language then Codesys is now available on the RaspberryPi for 35 Euros.
Greetings,
You may want to consider an embedded PLC. In this case we distribute the FMD88-10 from Triangle Research. The operating voltage range is 12 - 24 VDC.
The outputs are transistor, not relay and are not bound by the coil voltage of the board relay. So you will have the ability to operate in the 12 to 14 volt typical range. The variance is +/- 5%
More information can be viewed through the following link:
http://www.eternity-sales.com/tri-plc/fmdseries.htm
Should you require more I/O there is the FMD-1616-10 and expansion boards.
If you have any additional questions, feel free to post, pm or email to me.
Disclosure - ESI is an authorized distributor for Triangle Research.
Hi, I had a client upgraded their system to use a set of redundant PLC system with GE PLC CPE400, and a Citect 8.0 (2016) SCADA to get data with...
1,442
Hi, I frequently demonstrate automation product (that we make) to various customers. The system uses an AB7007 Anybus gateway that connects to...
16
5,256
we have plcs in our plant as given : Control logix 1756, Controller name : Logix 5571 HMI : Panelview Plus 1000 please suggest all required soft...
1,911
Hi, Is there any cheap PLC (less than 100 USD) that has 4 digital inputs/outputs (not relays), RS 485 communication, ethernet port (if possible)...
19
5,637
Hi, I need a PLC that operate as a MIMO PID controller.I design a project with simulink to control a system which is used PID controllers. my...
1,228
