PLC IP Address/OPC
My eventual intended application is software which I'll write to visualize miscellaneous data from variable frequency drives attached to a network of PLCs.
I'm not sure what data I can obtain from the VFDs (will cross the bridge when I get to it), but voltage is one example.
My custom software will talk to the OPC server (KepserverEX) which in turn will be connected to the PLCs.
The model of the PLCs is Allen Bradley CompactLogix 1769-L35e. The VFDs are PowerFlex 753.
My initial step is to first play around with a single Allen Bradley PLC (MicroLogix 1400), see if I can connect to it via Kepserver. This part seems straightforward -- the PLC can be directly connected to the PC running Kepserver using an Ethernet cable.
I'm just curious how I'd connect to a network of many PLCs. What will my PC be physically connected to?
I think you are overthinking it...
Connect your PC to a router and set the IP address to static via the Ethernet port, do the same with the PLC, in your OPC/HMI software you would address the PLC/Tag address and pull the data
This is not on topic but...
be very weary of "roll your own". The exception being on a hobby project or for a OEM machine that will be duplicated 100x times. A one off super duper custom software can be very difficult to support in the future.
Noted. For the moment, this is a hobby project, but it can potentially be turned into a product. It'll just be a visualization layer on top of existing OPC software (Kepware).
Edit: title is wrong: 1756. Sorry. Hello. Is there a way or an instruction to retrieve the CPU IP Address from the program (and assign each...
816
Hi everyone, I am working on a project to protect program memory on Omron CP series PLCs. there is several ways to write protection that i've...
610
Having an issue connecting to my Micro820 PLC. I don't have an IP Explorer and I know its MAC Address is 5C:88:16:D8:E6:65. I'm connected to the...
901
looking for the the MAC address for this PLC, I count find it in the front or at any part of the PLC itself. connected to the PLC by USB, showing...
1,754
It might seem like a stupid question but please let me elaborate. I had a PLC that already had some IP address on it which I needed to change. My...
5,727
