Stylus for PanelView Touch... ?
daba
Jul 2004
uk
5,401
I've had to do a considerable amount of "squashing" on some PanelView 1500 display screens, that I'm now concerned the touch areas are too close together for Bubba's fingers... There's no overlaps, but there's only a few pixels between buttons.
Has anyone used a stylus with the PV ?
What's the best type ?
Longevity ?
My client will accept a stylus solution, as they don't want the expense of replacing the HMI with a more modern unit that can do higher resolution than a PV.
Yup, we do similar thing, tie a pencil on a string. You can probably get specialized stylus.
Keep in mind, that panelview and other industrial touchscreen are resistive so only pressure is needed so any pointy object can work.
Yes, I use a stylus all the time on Panel View screens and almost any resistive touch screen, I buy ink pens with a pressure type stylus on the non writing end so I always have one with me. I'm sure a pencil eraser would work just fine, but I work in the food industry so pencils are not allowed on the floor.
But pens with ink in are allowed ???
79
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
54
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
169
Hello All! Ok, we got a Work cell from a Integrator that is sending saved scanning data from the PLC to HMI (Panel View Plus) when I look at this...
80
saludos a toda la comunidad Hace unos días he venido presentando pérdida de comunicación en una terminal hmi, anexo las imagenes de la secencia...
106
