quickpanel to fanuc robot
Scueter
Feb 2007
Michigan
Has anyone setup communications from a GE quickpanel to a Fanuc robot (R2000)? I know I have to setup the plc as a GE SNPX. The part I was wanting to know is how do I setup signal definitions. Does the quickpanel write directly to the DI/DO's and how do you setup the I/O?
I was recently stuck getting a Devicenet AB armor block mapping to the R-j3iB. The R2000s have a means of doing a network scan, atleast for devicenet, soemthing like the RSNetworkx. But i am not sure how! So I would guess, for the correct chassis mapping to your PLC, further to which you can map you DIs, Dos, GIs,GOs, you either need a driver file or a network scan. i wish I was an integrator and not the one buying stuff from an integrator!
Scueter said:
I know I have to setup the plc as a GE SNPX.?
Are you sure? I have never heard of a Fanuc Robot with SNP or SNPx capability.
You're not getting GE Fanuc mixed up with Fanuc Robots are you? These are two completly different companies.
I have a Fanuc R-30iA robot controller. I am using a GE quick panel for a HMI / operators panel. How do I define the robot I/O I would like to...
27
17,591
Has anybody setup a connection to a Fanuc (R2000) robot? I've got an existing application that I need to add some functionality to. I just don't...
4,087
Did anybody know how to send sms in quickpanel control.....iam struggling with that since 1 month....any tutorial is invited ......
1,479
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
331
Dear colleagues, hello to everybody! I have a problem with Quickpanel IC754VBI06SFD-GF Proficy Machine Edition Runtime 6.5 QuickPanel View V2.00...
654
