dpdp com: S71200 To Fanuc
userxyz
May 2002
any
2,768
I have a profibus connection between a S71200 and a Fanuc Robot. My 1200 has a CM1243-5 Profibus Master card. I have 32 byte's IO configured. Normally I would use DP Send and DP Receice (SFC14 SFC15) to do the consistent write and read trick. However, these blocks are not there for the S71200.
What block is the one to use here ?
Thanks,
Kind regards,
Combo
Hello....
in s7-1200 there are these instructions DPRD_DAT and DPWR_DAT
(DPRD_DAT = SCF14,DPWR_DAT = SFC15)
Hi, I need to receive data via a DPDP coupler. On the other side it's simatic doing blockmove. On TIA side it's like blockmove doesn't work on...
948
I'm retrofitting equipment, but I didn't want to change the electrical characteristics of the panel. In this equipment I have a dedicated...
68
Hi folks ! Got an older Modicom BM85 and I suspect that it's not passing data to ModBus+ network. We had a power loss for a few days and I suspect...
67
I need to recommend a PC to replace a customer's old Windows 7 computer. The only thing I need to think through is the serial com port to...
21
680
We're upgrading an old PLC-2 system programmed in ICOM. We have the files, the PLC logic is in a .LAD format. Does anyone have working...
422
