What (less expensive) network equip. do you suggest for light industrial networking?
tbennett4u
Jun 2018
Spruce Grove
Not a PLC specific question, but has to do with PLC network communications.
I need to spec out network equipment for a distributed data center, basically several building modules dispersed over a site, each module housing building automation for temperature control and a variety of computing equipment.
Looking for reliable, inexpensive networking equipment to facilitate communications for several networks (VLANs); a control network (within each module and from module to central SCADA), a data network (for distributed computing needs), and potential a business network.
Up for consideration right now are:
What less expensive make/models of network equipment have you used and how was the experience and results?
Any experience with Aruba or Ubiquiti?
I would ask 2 questions.
- Does it matter if the network goes down (production/data)?
- What is the plan for scalability?
With that in mind, I would have a dedicated switch for each vlan and not cut up the switches with vlans. This will save you and electricians a lot of head scratching when someone randomly unplugs from a port and plugs into the port next to it.
edit - I prefer Cisco but $2k a switch is a bit high, the NTRONs I've used work, but the few I had you needed to get comfortable before putting them in production.
I recently installed half a dozen Cisco SG-250 small business switches. They are working great. They don't work with Cisco Network Assistant, but do have a decent web interface. They're fanless and don't even get remotely warm while 40 or so IP camera feeds run through them.
I have several Ubiquiti switches used in a camera system, they have been powered up and working for over 800 days.
I'm using the Automation Direct Stride SE2 series now.
I was using NTRON for a while, until I realized that their per-port DHCP server was next to useless, and they refuse to upgrade it at all.
Currently working on a project with existing N-Tron and Hirschmann (Belden) switches. I priced a matching Hirschmann switch (6-port Ethernet and 2 SFP ports), and it came out to $286. I think that's a pretty decent price for a fairly industrial switch. They seem dead simple to work with too.
I would say Ntron or Hirschamann as well. However, if you have a place that like use all AB stuff including HMI then Stratix is nice because they make premade face-plate for that.
I use almost exclusively N-Tron 700 series switches. I stick with them despite the higher purchase price because they just work. Built like tanks.
My colleagues sometimes select less expensive or smaller-footprint switches. I usually chide them gently.
Today I looked in the shop and found a very large and very complex system using B&R motion and safety controllers on Ethernet, and was alarmed to find a fabricated shelf in the enclosure on which sat an office-grade TrendNet switch.
The designer actually told me "that's what [the distributor] uses in their demos and they never have any problems".
<cracks knuckles>
I have recently converted my home installation to Ubiquity and I love it.
Only thing I do not like so far is the small form-factor. The switches run pretty hot.
We have used WESTERMO in the past for industrial networks. Just dumb switches, but they worked very well. Might be worth a look.
I've been running a Ubiquiti Edge Router at home for about a year now without any issues. For reference, I had to reboot the previous router every few weeks.
However, anything other than the basic configuration isn't for the faint of heart. It's a pretty complex device once you deviate from anything the wizards will help you to do.
I'm sure everyone has a use for large screen status displays around their plant. There's been a lot of talk about different ways of doing it, most...
4,205
Hello Y'all, I was wondering if there is any standalone solution to replace the ethernet cable to connect to a PLC? like perhaps a "Dongle"...
26
2,336
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,020
Hi All, I am working with an outside vendor on a project, and they have asked if they can use Wireless IO link for one of their remote IO blocks...
1,130
Hello everyone, I have read a few threads regarding setting up an AP to wirelessly communicate with PLC networks, but I have a unique question on...
579
