PLC-5/40c read throgh serial port in ML1400
Thanks a lot. I got the data in ML1400 through serial communication.
As of now i want to send data to PLC-5/40C throgh serially from ML1400. I setup an msg instruction as PLC5 Write in ML1400. But when i download unknown error(Error Code:e6) will came.
Screenshot is attached for the same.
From the Micrologix 1400 Instruction Set Reference:
Error code E6: PCCC Description: Illegal Address, address does not exist, or does not point to something usable by this command.
Make sure N101:0 exists in the PLC-5 and is not protected.
I agree that the N101:0 data file should be verified to exist in the PLC-5 and to be at least 5 elements in size. We can't see that for sure from other screenshots.
I want to emphasize that the logic you are showing will re-trigger that message multiple times, rather than just once per second.
The combination of the LIM and the Output Unlatch (OTU) of the Message control Enable bit create a self-retriggering MSG block for 190 milliseconds, rather than a MSG that executes once per second.
I am posting (below) a screenshot of your existing logic, annotated to illustrate why it functions that way.
This is NOT the method I recommend. My recommended method is shown on the last post of Page 1 of this thread (link).
Hello, I am doing a positioning application for a paint spray machine. The horizontal indexing of the paint gun is done by a Tooth belt axis...
1,679
I have a customer that has (well had) a 1747-L40C, and drop the machine off the truck... it did not like the fall :) So they have a paper print...
2,639
G
I am new to this. I have a slc500 1747-l40c plc, and do not know how to connect to the dh-485 port on it. Can i use a straight cat5 cable and my...
15,456
the conveyor can stop because of a safety sensor or safety switch. And also it can stop because of an object jam detector sensor. If the conveyor...
85
28
