Converting Instruction lists from 90-30 to Rx3i
demond1984
Nov 2017
TX
I'm in the process of upgrading 90-30 to Rx3i, and the 90-30 has instructions lists in the program that are not supported in the Rx3i.:unsure: Any advice on what would be the best action to convert this into ladder/structured text?
I could be mistaken, but I was under the impression that there is 100% conversion between IL and ladder in the 90-30 and that 90-30 ladder is 100% convertible to Rx3i. Could it be that your 90-30 program is in SFC?
If you can post a backup of your 90-30 project file, I can try to help.
The Rx3i does not support IL blocks. The easiest approach is to convert the IL to LD. There was a conversion utility in Versa Pro to convert between LD and IL, but that utility doesn't exist in Machine Edition. I did quick conversion of the SP_AXIS block for you (attached). Be advised that I didn't proofread it or try to download it to a PLC. The other IL block doesn't appear to be called anywhere. At any rate, it is only two lines, so it is a simple enough conversion to LD.
Steve, sorry it took a while to respond, but I really appreciate the help on this!!!!!! You were a live saver.(y)
Hi guys, Another great weekend here in Wisconsin, it snowed 15" this week and I'm stuck working. Now that I've used my alloted time for...
3,511
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
205
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
120
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
314
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
385
