MattMatt9 Member M Join Date Jun 2020 Location Canada Posts 119 Jul 30, 2020 #1 Is the drive missing something or my computer?
dmroeder Lifetime Supporting Member Join Date Apr 2006 Location Vancouver, WA Posts 3,604 Jul 30, 2020 #2 Probably need to download and install the latest AOP. Edit: It's your computer, not the drive.
dmroeder Lifetime Supporting Member Join Date Apr 2006 Location Vancouver, WA Posts 3,604 Jul 30, 2020 #3 I'll try to save you the trouble, the AOP you want is named: Product: AOP for PowerFlex Drives and SMCs (all Logix versions) v5.07 Version: 5.07.00 Click to expand... There are others that will confuse you into downloading old AOP's, they are properly named "PowerFlex 525". Don't fall for it.
MattMatt9 Member OP M Join Date Jun 2020 Location Canada Posts 119 Jul 30, 2020 #4 I downloaded that exact file and it still says same message. Is there a setup file within the download or something?
MattMatt9 Member OP M Join Date Jun 2020 Location Canada Posts 119 Jul 31, 2020 #5 Theres a file called MPSetup...is that it?
dmroeder Lifetime Supporting Member Join Date Apr 2006 Location Vancouver, WA Posts 3,604 Jul 31, 2020 #6 MattMatt9 said: Theres a file called MPSetup...is that it? Click to expand... Yes, you need to run MPSetup.exe to actually install the AOP's.
Pablo_mejia Member P Join Date Jun 2021 Location Coahuila Posts 1 Jun 7, 2021 #7 MattMatt9 said: Is the drive missing something or my computer? Click to expand... if it worked for you?
cardosocea Member C Join Date Nov 2016 Location Fields of corn Posts 2,632 Jun 7, 2021 #8 Pablo_mejia said: if it worked for you? Click to expand... Not the guy that started this, but I had the same exact issue with a Powerflex 753 today. I did manage to get online with it by downloading the EDS from the drive. The AOP is 2Gb...
