Issue addressing 1756 IO channels and points
kandymann
Jan 2011
Virginia
168
Excuse my ignorance but I am having a hard time figuring out where my real IO points are to address tags.
Please refer to attachments for screen shots.
I have three (3) IO modules tied to a 1756-A17 chassis.
1) In slot 1 I have a 1756-OA16 digital output module. When I create a tag for an output and I search for the output point I simply cannot find it. All I see are 32 points instead of 16 (see attachment 1756-OA16)
2) In slot 2 I have a 1756-IA16 digital input module. When I create a tag for an output and I search for the output point I simply cannot find it. All I see are 32 points instead of 16 (see attachment 1756-IA16)
3)In slot 3 I have a 1756-IF16 analog input module. When I create a tag for an output and I search for the output point I simply cannot find it. All I see are 8 channels instead of 16 (see attachment 1756-IF16)
Thank you very much for your help!
1756 IO.jpg 1756-IA 16 (1).jpg 1756-IA16 (2).jpg 1756-OA16.jpg 1756-IF16.jpg
Do you have your IF16 running in differential mode? if so, you'll only see 8 inputs as differential uses 2 inputs for 1 channel.
As for the IA16 and OA16, I believe they always represent as 32 bools.
.0 -.15 are the usable ones corresponding to each input/output.
Hey, I'm having trouble with moving data within a DB and I think the problem is rooted in my lack of understanding of programming 'pointers' so...
27
6,078
I'm trying to set up a project in Cscape for a new install. Our config will be an RCC972 with 2 SmartBlock I/O's - HE579DAC207 and HE579MIX105...
1,553
Hello All, I was installing a 1785-ENET card on an existing 5/60B processor. Before installing i moved an 6 point AC input card from slot 0 (next...
2,993
Hello all, I am currently working with a Control Logix 1756-L72. Using studio 5000 v. 23. I also have a 1756-ENBT Ethernet module plugged into an...
2,096
Hi all, I'm having an issue with indirect addressing. I haven't used indirect addressing all too extensively, or with this level of complexity...
16
3,392
