color animation of an object
FMorin
Apr 2006
Longueuil
My second day as a member and already a second question. I Hope I’ll be able to help someone someday…
Here’s the (multi)question: (again, I’m working on RSView Studio 4 (CPR7))
I’m trying to animate the color of an object(polygon) with this expression:
If ({tag1} == 0) Then 0 Else If ({tag1} == 1) Then 1 Else 2
tag1 is digital
1rst: what is the meaning of the {}?
2nd: When simulating, I receive this error:
Expression contains a tag that has an error value
After looking in the RA: KnowledgeBase, I’ve founded this post:
http://domino.automation.rockwell.com/applications/kb/RAKB.nsf/0/278665D22EA125B485256ECA006A86F4?OpenDocument
I don’t understand this answer, why creating a folder?
If I understand correctly, I’m comparing an integer with a bit and that’s not possible but I’ve tried to change the type and data type of tag1 to Analog and Integer, but the same error appeared.
3rd: would it be possible to use this expression, (I’ve tried but got the same error msg):
If {tag1}Then 1 Else 0
Meanings (for me as I understand it…):
if tag1 is true then 1
many thanks(!!!)
Being that this is a digital tag, just select the tag in the "expression" textbox don't add any other "logic" - just the tag, then select the color you want for the on state and the off state below.
Your "expression" has a minimum of three states 0, 1, and not 0 or 1. That is not possible with a digital tag....
See attached:
Hi, How do I change a numeric display color based on another bool tag? I am trying to display a RPM number and I want it to turn green when a tag...
2,181
Hello everyone, The title above kinda explains the whole of the problem as far as I can see. I'm working on a project with some text in it...
2,180
I am trying to program an HMI to show a different color based on the number it gets from the PLC to indicate if the message is a Fault or just and...
1,149
Hi Guys, Urgent help please. I'm stuck, how can I add color animation to a Tank or any object in Mitsubishi GT Designer3? I'll appreciate
3,426
I am unable to find the valve with colors(green,red) in TIA 13 for HMI. I have to import it separately or is there is any other way around.I...
2,033
