Writing out to Universal Robot dashboard socket 29999 through TCP/IP from AB Complogi
Nortech
Mar 2018
Spain
59
Hi All,
Has anyone written commands to a Universal robot dashboard through TCP/IP socket from an Allen Bradley Compact logix PLC?
I'm using the Modbus TCP Master Sample Application example from the rockwell website and seem to be getting connected momentarily before the connection is dropped.
Has anybody got any experience with this?
Hi Contr_Conn,
No. I didn't but following through the Rockwell sample code, I can see that the PLC closes the connection due to no response from the robot despite the Initial MSG blocks seemingly creating and connecting to the socket successfully. Have you done this before?
Before you dig into the working code you should see what is on the wire.
Then it will give you a direction.
You may need to replace your slave device with some Modbus simulator and get it working this way.
There is also Quick Start technote that has exact example.
I am not sure how to do this.
I can communicate with the robot socket from my PC using SocketTest v 3.0.0
How do I check whats on the wire?
Heres what I have: (1)ezTouch model EZ-T10C-FU Touch screen with Universal Ethernet port. (2)1769-L35E/A LOGIX5335E PLC I am having issues...
3,522
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
191
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
90
Hello All: I have a Windows 10 PC running a FTView ME Station 10.00. I have a .mer file version 6.00. It has been running well on it for a long...
164
My R55 Ingersollrand is tripping on motor overload and im falling to see the trip history it is writing Acquarring texts
132
