Rslinx not opening
Kingiie1973
Apr 2010
Bargo
We are running logix 5000 version 15.02.00 and are able to access all programs on site via rswho without issue.
When we try to open rslinx classic the program freezes up every time.
I have tried deleting the program and reloading without any change.I am not able to access linx to get the version we are on!
Any suggestions would be greatly appreciated.
Cheers
Have you tried another PC?
The first thing that it does is load the drivers... this is why I have them manual starting, I have had an issue with it like that once after I loaded the wrong driver, BUT reloading Linx too care of it
I have uninstalled 2.51 then reinstalled 2.52 and still get the same thing.
It opens to the start page but has the hour glass and will not do anything. If i open 5000 i can "who active" and see all processors on the network and go online as normal.
I am not able to use another pc as this is the only one we have acess to. Thanks again
Then RSLinx is probably running as a service. You would get online without it.
Hit "start" -> "programs" -> "Rockwell software" -> "RSLinx" -"RSLinx Classic Launch control Panel".
From the pop up window select "Stop"
Uncheck the "AlwaysRun As A Service" tick.
You're good to go!
Nah nobody in Oz drinks that stuff its mostly exported! and its not real good. Thanks to everybody for your help.
Have a good weekend
great answer micky. It helped. and its working . i had the same problem . on opening rslinx, the systems doesnt show that its running and neither allows to provide new paths. after starting and stopping the rslinx, it works now. bravo bro!
can't open rswho in rslinx
after restarting services of harmony in administrative tools of control panel, showing me this kind of error in opening rslinx classic. regarding space but there is too much space in local drive C.
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
180
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
229
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
141
I need to support some old data collection that is running on Excel, but I need to get it running on LibreOffice. The following statement works...
82
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
153
