PlantPAx Object for Controlling 2 state device
Jul 2007
Kiruna
600
Anyone familiar with the PlantPAx library?
I have a few simple devices I need to control. 2 outputs for open/close and 2 inputs for status opened/closed.
I could use a P_Valve or P_Pump object and rename it but curious if sometime already exists for a simple 2 state device.
Thanks in advance
Simply because it's an electrically actuated clamp and not a solenoid valve.
Sure it will fit the purpose but I was just curious if there was such an object in the library for a generic 2 state device.
You could create a UDT containing a pair of DIn, DOut, and perhaps some custom commands/states that are associated among them. Think of it as an equipment module containing its control modules.
However, I lean to Ken’s idea because you could easily enough copy and rename, or rename outright, the P_Valve AOI to be “P_Solenoid”.
Dear Members, Hello, we are working on a project and facing an issue with the plantpax 5 PMTR library, we have a bidirectional motor, which has 2...
185
I spent today playing with this. Its great if you ask me and extremely flexible. What stumps me is they spent quite some time developing it and...
3,132
I've been using the PlantPax add-ins for RSLogix5000/FTV and I've been having the ongoing problem of the supplied global objects going crazy on...
2,965
Hello All We have 3rd party vendors that run on older versions of PLC (Plc2.0) while we run the main system using plantpax and PLC 3.5-10. Plantpx...
50
The PMTR has a timeout parameter for run feedback during a start, but once the motor has been running for a while and loses that run feedback (to...
195
