Sprecher + Shuh PLC
paulc20
Apr 2002
Bathurst
32
Has anyone any experience with the Sprecher + Shuh Sestep 290 PLC. Our Australian distributor teels me that it is obsolete and I cannot purchase a programming cable. I believe that the cable incorporates a RS232 converter to 442 or 485. Does anyone have pinout details etc?
Paul, did you ever get the SESTEP 290 sorted out? I have a SESTEP 290 with no documentation and no program listing and need to get the program out for migration to a modern PLC. I have only a hand held programmer also without documentation. Any advice would be appreciated.
Hi. Have a talk to your local NHP rep. I have found that they will usually lend you a cable (and software) to download the program from these peices of garbage. Alan Case
I have borrowed the cable off my NHP rep previously, and I do have a copy of the software on an old hard drive somewhere if you cannot get it.
The last time I went to borrow the cable my rep had lent it to somone else who did not have the decency to return it, therefore I am stuck.
If I could find the pinouts of the PLC I would make an adaptor.
Sestep 290 PCV 20
Hi guys,
I desperately need the software for a Sprecher and Schuh sestep 290 PCV 20 plc. Is there anyone that can send it to my e-mail address?
I have the connecting cable, only the software is missing.
Gerhard
Cable for 290
I have a S+S 290 and software is available to me on loan. I don't have a cable or distributor.
Did you have any success with the cable pin-outs and/or conversion in the cable.
Regards, John
Some Sprecher + Shuh PLC's are 100% identical with Hitachi. Two weeks ago I replaced a CPU of Sprecher + Shuh with an Hitachi.
The replacing wasn't the exiting part. I had to download the software as wel. I downloaded and uploaded the programm using the ACTSIP software that is used to programm the hitachi PLC's.
For the series that we used it worked great. But I don't know if it works for all series of Sprecher + Shuh.
Good luck.
Sprecher & Schuh 290 PLC
The Sprecher & Schuh 290 PLC is not a badged Hitachi model.
The 390 series upwards were rebadged Hitachi PLC which are still available.
The software required is PRS21 which I have available. I also has pinouts for cable connections. The lead is RS232.
Can you help me ?
Hello Parker,
I do need the software PRS21, en the pinouts for the cable connections; can you help me ?
My email adres:
[email protected]
Thanks very much !
Hello Parker
Please send the manual !
"I have a manual in pdf format for Taian PC10 / Sestep 290. i will be happy to mail it to anyone."
Hello olerasmussen,
Can you send that manual to me please ? It will make me very happy !
My email adres is:
[email protected]
Thanks very much !
sankhoms
I have a PRS21 program for PLC'S SPRECHER+SCHUH SESTEP 20 but I don't have user manual for PRS21 program . Kindly sent me please,
user manual for PRS21 program.
Thank You Very Much
Sankhom
email: [email protected]
Hi all, I have searched this site and googled the www, looking for a link to the SESTEP 290 user manual with no luck. I am trying to convert the...
2,501
;) Hi, I am looking for a documentation on the Sestep 300 PLC. I have to translate a program in a modern PLC, and i don't understand some...
3,610
Hallo to all. I have been tasked by a client to replace an old Sestep 290 plc with an Omron. They have the PRG 20 hand programmer. I could really...
1,192
Hi All, I have a project in which I should link Sprecon-E-C Controllers from Sprecher Automation to modbus devices and read their values. I have...
1,101
Hi, Is there anyone who had an experience of working with Sprecher products like Sprecon V460 and its PLC systems. I will appreciate it if...
1,753
