[Newbie]: Siemens - WinCC - What is the required license for WinCC SCADA redundancy?
DenZ_P
Jun 2016
SomeWhere
64
Hello Guys,
Newbie with Siemens here. I will be configuring and deploying for a project of mine for WinCC redundancy.
I have read this article in siemens website that for WinCC redundancy you will be needing the following below:
  • WinCC Redundancy Option includes licenses for both redundant servers
  • A redundancy license is required on each of the two servers in addition to other necessary licenses
Link below is where i have read the article about WinCC Redundancy:
http://w3.siemens.com/mcms/human-machine-interface/en/visualization-software/scada/wincc-options/wincc-redundancy/pages/default.aspx
So I am kind of confused if I need a redundant server license and then a separate redundancy license for each of the workstation? Or is it possible that i can just have two redundancy license?
Also below is the information for the WinCC Redundancy license being provided to me by our automation supplier. He/She Says that i need to purchase two of the license below to be installed in each of the station.
6AV2107-0FB00-0BB0
SIMATIC WINCC REDUNDANCY FOR RUNTIME PROFESSIONAL V13 UP OPTION F. WINCC (TIA PORTAL) RUNTIME SOFTWARE, SINGLE LICENSE F.2 INSTALLATION WITHOUT SW AND DOCU. LICENSE KEY ON USB STICK, CLASS A
Please comment if the above license is applicable for redundancy and if i really need to buy two and not just one. thanks!šŸ™ƒ:confused:
Hello All,
Just an update about this thread. I found an answer to this question.
Below are the ones that is compatible. Thanks!
WinCC RuntimeTime Professional v14 - 6AV2105-0FA04-0AA0
WinCC Redundancy for RT Pro v13 - 6AV2107-0FB00-0BB0
also there is an online compatibility tool in siemens website.
Siemens Compatibility Tool Link
Thanks! And keep helping each other out.
Hi - I am unfamiliar with Siemens PLCs but have been given ownership of an S7-300 CPU318-2 with IO and a network interface card at site. The PLC...
18
4,329
I picked up a Siemens S7 1200 from a buddy and I want to start fiddling around with it to learn about PLC's. I don't want to spend a lot of bucks...
2,494
I have a project I am working on that will be deployed at all of our sites (globally). Basically, we'll have a PLC that operates some fairly...
3,807
Hi everyone, I am new here in this Siemens world.Any Ebook, Tutorial or guide to learn siemens step7 programming TIA portal, WinCC?
1,569
Hi people I'm new to the forum and I'm in need of a little bit of advice if anyone can help, I've been tasked to make a small modification on...
1,625
