FactoryTalk Directory
Damien1
Nov 2017
Quebec
Hello,
I have a FactoryTalk View SE 8.10 system. There is one server who holds the HMI Server and there is one client connected to the server. Everything were fine but after a long power shortage (UPS goes down), a bug appears. The HMI server is still working fine and the faceplate can be controlled from the client like before, but there is a message that comes each minutes in the log window at the bottom of the FactoryTalk View SE Client :
Error: HRESULT = "0x00000000" Location = ".\RNADirServerProxy.cpp, Line: 16838".
The connection to the FactoryTalk Directory has been restored.
Error: HRESULT = "0x80072746" Location = ".\RNADirServerProxy.cpp, Line: 17452".
The connection to the FactoryTalk Directory has been lost.
I tried to repair FactoryTalk Services Platform with no changes. When I try to configure FactoryTalk Local Directory on the server side (run as Administrator), I get an error :
Unable to backup existing LocalReconfigure Directory to file folder C:\ProgramData\Rockwell\RNAServer\Backups\LocalReconfigure2891.bak.
Exception from HRESULT : 0x80042034
Is there anything I can do to resolve this without reinstalling everything ?
Thanks a lot,
Damien
Same error as like you faced
I tried reinstalling FactoryTalk Services Platform and it doesn't change anything. But I found this tool in the Knowledgebase and it was successful after using it.
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/577717
I have faced the same error.
Unable to backup existing LocalReconfigure Directory to file folder C:\ProgramData\Rockwell\RNAServer\Backups\LocalRec onfigure2891.bak.
Kindly suggest for resolution.
Tengo este problema luego de reiniciar el PC, he encontrado solucion cuando el proyecto es ME, requiero una solucion para un proyecto SE La...
1,460
Hello all, I have an example scenario 1. Host serving FactoryTalk Directory server is on 10.125.54.32 2. Client 1 is on host 10.125.54.33 ...
1,540
Hello all, I am trying to "Specify a FactoryTak directory" to another computer on the network. But my local admin username and password generates...
1,677
Hello, I am stumped with logging into the remote directory located on a server setup with a Network Distributed Application. I can't seem to get...
1,125
Hi all, Im having some issues and hope you can help. A customer wants an existing Panelview Plus connected to their Active Directory. At the...
2,276
