Is communication with PLC-5/30A and 30C over Ethernet/IP supported?
m.nazish
Sep 2008
India
39
Is there any connection between Ethernet/IP and PLC-5/30A or PLC-5/30C? I mean if we use PLC-5/30A or PLC-5/30C for communication with Ethernet/IP, will that work?
Please help.
URGENT!
Thanks in advance!
You'll need an e-net side car module. Check the AB web-site for series
and revision compatibility. In addition, if the side-car is an option
you'll have to free up the slot right next to the PLC.
Good Luck
(8{)} :) .)
(Yosi)
So u mean to say that communication with PLC5/30 series A and series C over ethernet/IP is possible but the processor require e-net side car module?
There is also the possibility to use a 1761-NET-ENI connected over serial port of your PLC-5 if it is free...
Just it is not a "direct" ethernet connection, but it is bridged over serial port (speed max 19200 bps :cry: )
- [font=comic sans ms,sans-serif]fuzzy logic[/font]
i have two plc 1. s7-1212dc/dc/dc ip; 192.168.0.1 2. s7-1500 1513-1pn ip; 192.168.3.2 i need to get data from plc1 to plc2. any idea how to do...
204
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
193
Hello We have installed several G.E. Fanuc 90 70 PLC Everything was ok but suddenly we can not communicate anymore with any PLC with the software...
100
Apologies for not being the best IDEC programmer. I recently was doing some inspections on a site that had 3 FC6A IDEC processors. The issue is...
118
176
