FactoryTalk View SE "TOUCH" property in FactoryTalk View ME
wanher3
Feb 2018
USA
65
Hello,
I have a graphic in FactoryTalk View SE that uses aTOUCH property to set a tag value equal to 1 on release. Im looking to implement that same graphic property in FactoryTalk View ME but ME doesnt have a TOUCH property.
How can i implement a graphic with FactoryTalk view ME so that when it is pressed and release, it sets a tag value to 1 ?
Create an invisible or maybe its a transparent button. Look at the buttons properties like color, size and boarder width and I think its in there.
I don't have ME loaded and its been awhile.
HTH
im not sure im following. Those buttons dont have an Action property field where i can say ...TagName = 1.
Oh hell, you made me fire FTME up. Look at the button actions and see if value will get you what you need.
You have three choices on a momentary button, NO, NC and Value.
I believe Dravik was referring to what is posted in RA knowledgebase 183862 and explains a ME workaround.
183862 - Is there Touch Animation in FactoryTalk View ME
Access Level: Everyone
Well not really because in SE, some of the actions on release are conditional statements like
If (Cond = x) THEN TagNameX = 1;
Else TagNameY = 1;
ENDIF;
Any other ideas ?
Did you read about the value option for the button? Sounds like you can set that to do what you originally asked for. Unless I'm missing something.
Edit..I haven't used the value option so I could be talking out my lower vent.
The value option doesn't allow to set a tag value based on a conditional statement. In fact, the button properties have no field to enter a conditional statement.
I have a control list selector with 50 states. My problem is that it's inconvenient to go through the list by ramping and then landing on the...
8,440
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
129
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
163
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
120
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
200
