Panelmate Pro config download
kevin91172
Feb 2007
NEEDVILLE,TEXAS
48
I got a new Lap top with just USB ports.I have got a RS-232 adapter and know it works an other things.Problem is how do I edit The PanelMate Configuration Editor(Version 2.10.6.10c6)port paramenters for I can Up/down load?
Steve I emailed Eaton on this,But always try this site to see who will help me with my Tech. problem first and this site always win so far.My computer has 3 USB ports 4,5,&6.I found an easy solution with Directsoft.Lets see what they got for me.
From Control Panel, you can change the assignment of your USB port to any COM port not currently in use. Go to the device manager, expand the ports and right click on the one with your adapter. Look at the properties/Port settings/Advanced to get to the COM port setup.
I did not have that "Privilege" to go under advanced.BUT Eaton called me back.If I have the app.is opened and plug in the device it will not rec. the new com.under port par.I had to close the app.,reopen then BAM it was just there.Got me config. downloaded,now I'm going home to have a beer.
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
511
I have a damaged PanelMate ePro HMI and looking to swap it out with a PView or C-More. I have the Panelmate project but not the Canvas software...
1,087
Is it even possible to get the Panelmate Pro software anymore? I have two .PPS but willing to convert to a new HMI. Appreciate any help.
1,692
Hi, We've purchased a new laptop with Windows 10 and I'm wondering if our Panelmate Pro software can run on it somehow? We have a Windows 7...
1,327
Hi Everyone I have a faulty Cuttler&Hammer Panelmate I need to replace with a AB PanelView. I managed to transfer the .PPS file from the unit but...
18
4,970
