FTView SE & ME
cdnewman
Jul 2017
Huntsville, AL
20
Morning Folks!
I came across an old VersaView HMI that appears to be running FTView SE and not ME. My experience with A/B doesn't date back quite that far and I am wondering what I'm up against. I need to make some changes to the HMI and all I have is ME software. Any help would be greatly appreciated.
If it's running SE for sure, you will need SE software to make changes. The software itself isn't really all that different from ME, though there are a lot more capability with SE. It's almost certainly running as a standalone SE application, but I don't know of any way to make changes other than getting your hands on a copy of SE...
If you can exit the runtime and click the "load application" button in ME station, that should show you the last area you loaded from. Copy the .mer file to your PC that has Studio ME, and use the application manager to restore the runtime application. If your PC is x64 bit, you will need to use the legacy tag database converter to convert the project's tag database before you can open it (but after you restore it), but know that once you do that you WILL NOT be able to restore the program from a runtime in the future. This is the case with ANY runtime created on a x64 bit station for a platform running firmware 5.10 or older.
Make sure you make an APA of the project to back it up after you've converted it.
I've tried that approach. I get a pop-up that says the "Runtime App was saved in an older format that does not support conversion to a development application."
You get that message when the .mer is created with the option "Never allow conversion" selected. Unfortunately, at least to my knowledge, there is no way around this protection.
If you don't have an APA, you may end up having to rebuild the program yourself...
Ahh, so the plot thickens. I have an apa from a sister machine, but it's been upgraded to a PVPlus running ME 7.0. So from what I'm reading, it may be time to junk the VersView and replace it with a PVPlus and build a new runtime from the sister machines APA. Does that make sense?
If that's the case, he's definitely going to be SOL without either a file structure or an APA...
Is there a temporary file structure created on the versaview when it's RUNNING the mer? I seem to remember being able to copy some .gpx files from a PC that was running station one time to take a shortcut in rebuilding a program, but it's been years...
Hello, I am fairly experienced programming and modifying existing FTView ME programs. I have also used FTView SE to make modifications to a...
131
Hi folks. I have a system that I'm working on that needs 2 alarms banners with different event subscription: - One banner for a specific area...
212
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
53
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
205
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
251
