Panleview Plus 600 won't grab the tags!
frodo88
Nov 2017
Illinois
I am fairly new to programming PLCs and HMIs. I have been tasked with converting a Panelview Standard application (Panel Builder 32) to Panelview plus 600. I was able to convert via FT studio and I was able to establish comms with my PLC (SLC 5/04) through DF1. If I go to RS Linx Enterprise in FT view I am able to add the DF1 driver and then browse to the PLC it is going to communicate with. I hit verify and I get these message for my shortcut saying;
"Path to design device is assigned [SLC Device]"
"Path to runtime device is assigned [SLC Device]"
and above these two notes I believe it displays the server name which is pretty long address. So here is my problem. Every time I run the application through the test run, I get these errors saying;
"Problem writing value to OT_CURRENT_SCREEN" (this is my welcome screen)
and it list bunch of addresses, for example
"Failed to resolve item's ID ::[slc]N7:002 because it does not exist on any server".
Can anyone point me in the right direction and tell me what I am missing? As I suspect, it is looking for tags but can't communicate or not sure where it is located at? Any help will be really appreciated.
The OT_CURRENT_SCREEN should be setup in the Global Connections under the display tab. You will find it under the System Folder in the explorer pane. There are two tag connections there one for Replace Display Number and another for Remote Display Number. If you are using the PLC to control opening the display each display must have a unique identifier. That tag must be returned to zero to allow operator control of displays.
The other addresses you need to make sure your shortcut names in the tags match the shortcut name in the communication setup. Also your tags need to be in the controller scope and not program scope tag database in the PLC. If you use program scope tags they must be identified in the tag connection.
I am trying to connect PLC5/30 to panelviewplus 1500 with 2711P/RN6 on DH+. I am plannig to load the program to Panelview on ethernet. Then I...
2,340
Hi, guys, how r u? There are two panels on our production line. One is PanleView 1000 and another one is PanelView Plus 1500. Can we...
2,513
Hi all, I have an AB Panelview Plus 700 and am trying to print a screen through the USB port. When we plug a printer into the USB port we get...
10,608
Hello my first time posting so hope i do not confuse you guys. I am wanting to store data from my vibration/Temp sensors that my PLC is already...
1,986
Heloo. Can someone help me how to factory reset PanelView 600. 2711-B6C1. Thanks.
56
22,468
