WinCC 6.0 Picture Module Technology
lucifer
Nov 2003
52
I am prpapring faceplate (ubiquitous Pump/Valve or PID pop ups) in WinCC 6.0. I am not getting how useful the Picture Module Technology ("Picture Module Template" and "Picture Module Instances" tool in the Dynamic Wizard) is in this context. I was partially successful in creating a typical pump faceplate using this technology. Partially because the "Picture Module Template" or TypWizard allows you to link faceplate object properties with Structre tag elements but not the events.
So I was able to link "IO Field" or "Status Display" objects ( "Output value" and "Index" properties resp.)on the faceplate with Structure tag elements but not the Button as there is no property of the button I could identify to link with.
The help manual does not talk about linking Button.
Is there any solution aroud using C scripts or something (may be using function GetLinkedVariable)
Hope I am clear !! Any insight or examples will be highly appreciated.
I wonder why people don't answer my queries !! Is that my username??
All I asked is a simple question that what is a best practice for creating pop-ups/ faceplates in WinCC ........that's all.
I am still exploring the options & I am glad to know that WinCC provides lots of options.. like VBA, VBS and C scripting and those Dynamic Wizards...just confused what to use.
Just kidding.
isnt there any answer to lucifer? i have same problem...
Oh....hi there.
So what's your problem? People don't answer your queries or is it WinCC? (JK....this is a great forum and I have immensely benifited from it)
Regarding Picture Module Technology, it is possible to link buttons.
But I would suggest the better way of pop-ups in WinCC is use TagPrefix property in association with Structure tags. It really makes life easy.
Well, please elaborate your query and I will be happy to answer.
i guess wincc is hard a little bit when it comes to faceplates i have same problem i am trying to create a smiple faceplate all i want to know how to link it to any tag i have got i cant link face plate to my tags i dont know what i am missing and why is it that hard i am using graphic designer and latter on i need to make a script on that faceplate but i cant have it running i dont know why is it that hard please help me loool
Dear colleagues I am trying to load a project from the multi-project in wincc. I will tell you about the procedure that I've done I've...
5,290
Hello community, There is next issue connected with executing script in the picture window. It doesn't depend on code , it depends on the...
20
15,336
Hello everybody! I'm doing dynamically change of graphic object pictures by action script in the WinCC 7.0. And it works only in the chain...
2,699
Hi All I am busy with a project where additions are to be made to an existing WinCC v 7.2 Single user project. I managed to get the project...
2,156
Hi all, I am using WinCC V7.0 I have created some menus and toolbars in WinCC Explorer and now need to bring them to life. I have a starting...
3,921
