.mer saved in a protected format
.mer is actually a 7zip file. You will need to know the password, Or you will have to figure out how to break a 7zip encryption key.
Have you tried restoring it by leaving the password field blank?
A common oversight is when someone creates the .mer they leave the encrypt box checked but don't enter a password. This will bring up a password prompt when restoring the .mer even though there was no password entered.
From wikipedia. An impressive amount of effort required to brute force a key!
Breaking a symmetric 256-bit key by brute force requires 2128 times more computational power than a 128-bit key. Fifty supercomputers that could check a billion billion (1018) AES keys per second (if such a device could ever be made) would, in theory, require about 3×1051 years to exhaust the 256-bit key space.
Dear All, I need a sample PLC program to count the output pulse of a mass flow meter so that a specific amount of mass (for example 100gm)can be...
79
Hello, I have a CNG compressor that is run by a PLC. I tried to get team viewer on it to be able to view it remotely, I accidently disabled the...
94
Hi all, I have a simple question that I have overcomplicated and gotten stuck on. I have a variable, we can call it "light" that I need to stay...
215
Question to anyone with ideas about my thoughts on upgrading a very vintage timer, which is being used to switch between 2 5hp domestic water...
364
I need a good website or tutorial to learn plc programming Thank you
461
