Low Cost Ethernet I/P VFD
Greg Dake
Jun 2005
Milwaukee, Wi
550
Greetings,
I am looking for some ideas on low cost VFD's which natively support Ethernet I/P. Looking for 3 phase, 480V, 2h.p. and less. Just need them for conveyor motors, no elaborate control.
TIA,
Greg
Personally I'd avoid Schneider drives like the plague. I did a project earlier this year with the Altivar ATV320 controlled by an S7-1500 plc over Profinet and it was a nightmare. Such a rigmarole to just get them to run and their tech support people in the UK and in France still haven't been able to tell me a method that works for clearing a drive fault using the reset command in the control word. Another nicety I found is that if you use STO on them and they go into a SAFF safety fault the only method I have found to clear this is by doing a complete factory reset.
Hi Folks,
Thanks for the abundance of response! My standard is the PF525, however I am trying to find something less expensive.
Greg
I was in the same boat.
I looked at several drives: Siemens, Schnieder, lenze, other Allen-Bradley (pf 40/etc) and they all seem to run pretty close together in costs by the time you figure the drive + communications card.
They are close enough to be a wash.
IMO, just pick a drive based on controls. Use PF525 for Rockwell, G120 for Siemens, etc.
I'd sure be interested to see some real numbers from an OEM / Integrator. AB prices are all over the map, depending on who the customer is.
Hi guys, May I ask if you know of any device with as few as 3 inputs and capable of ethernet connectivity? I have a project to monitor a number...
20
6,767
Hi folks, We have been working on our own controller after many decades of using the "big names". What would your ideal motion-controller be...
48
8,245
I was wondering if any one had an idea how I could implement an amperage reading to the plc. I have two PWM valves which draw about 3 amps...
1,612
Hi everyone I'm in the process of automating my home brewery. To get control of levels i was thinking of measuring the flow of water into the...
8,974
Hey all I know this is kind of OT for here but anybody know a good single channel data logger I can log values to a laptop, with some graphing...
1,582
