Connecting to AB 1769-L32E
sparkytex
Jun 2013
Port Hardy B.C.
354
Hello All,
I have a 1769-L32E Compact logix processor that I need to connect to. It's sitting on my desk with a power supply attached to it and powered up. I have a desktop with RSLogix 5000 and RSLinx set up on it. I do not have a way to connect to the Processor VIA RS232 9 pin. All I have is an Ethernet patch cord plugged into the Ethernet card on the desktop and processor Ethernet port.
What are the steps I need to take in order to set up a driver in RSLinx to communicated to this processor as I have to load a program onto it as well as download Firmware Rev 17.2 onto it. The desktop has a static IP as its used for an HMI station on the PLC network that I'll be putting this new processor on.
I want to be able to load the program onto this processor and swap it out with an existing one that is already connected to the PLC network and is running.
thanks in advance,
Tex
When you use Flash you can use Bootp and assign the address to the PLC then flash it
Or you can just get a crossover cable or null modem cable for the RS232
Here is a video I did awhile back that may help...
Allen Bradley 1769-L32e setting up Ethernet and flashing CPU http://youtu.be/FkO2BBuuwJw
Make sure you dont have both CPU's on the network with the same address
So In order to connect via Ethernet IP driver I first need assign a static IP address to the L32E's Ethernet port with a DF1/RS-232 driver in RSLinx? My issue is I have no way of connecting to the processor via DF1/RS-232 as I have no cables to make that happen.
No, you can open ControlFlash... try to update a L32e with your address you want to flash, after a min it will error out and you can enter in the mac ID, by doing this it will use Bootp and will assign a IP address to the PLC, then you can flash it with using Ethernet IP
You do not need a serial cable but surprised if you dont have one laying around?
there isn't a 9-pin port on this desktop nor control flash, so it seems I'm out of luck at this moment. Is control flash free to download, and is it downloaded from Rockwell?
I have a L33ER that I am having issues connecting to in the I/O Configuation of a 1756-L83E. I have established a connection from the I/O...
2,348
Hi We have a project that is based on an AB 1769-L33ER and I need to connect this to our InTouch 2014 Scada system. We have installed the latest...
2,408
I am new to PLC programming, and have most of my experience in offline edits. I am trying to connect to the L24 through an Ethernet switch. I have...
3,685
76
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
83
