cx-protocol
scornush
Mar 2018
saudi
dear sir's,
i have OMRON CJ1M CPU with SCU41-V1 CARD for RS-422/485 communication with omron inverter of model V7 via PMCR(260) Instruction. now i want to replace the V7 inverter with V1000. i have made all the port settings and parameter settings for V1000. but i am not much familiar with cx-protocall. i wnat to edit the send and receive sequence for V1000. i have the sequece as mentioned below for V7 inverter. please can some one help me on this regard.
send message for v7 inverter was written as mentioned below.
send msg:
SD(0)_1 <a>+[100118000102]+(R(2),2)+<c>
SD(1)_1 <a>+[0300230001]+<C>
RECEIVE MSG:
RV(17)_1 <A>[0302]+(W((1),2)+<C>
i could not understand the data [100118000102] which was not clearly mentioned in any of the manual.
thanks and best regards,
anushamoorthy.s
cx-protocall
dear sir,
thank you so much for your prompt assistance. here we are using modbus communication. in the PLC program we are using {PMCR(260) instruction with control word 1 as #110(position 0 is used for scu41-v1 card), with control word 2 as (&212, &239, &240) sequence no (1, 14, 15) in the attached photo (1.modbus sequence),& first send word with data of frequency reference1,2,3,4 & acceleration deceleration 1,2,3,4}. the above said program was done for V7 inverter in that i have replaced part of V7 inverter with V1000 which falls under sequence 1(&212). i would like modify this sequence to communicate with v1000 inverter which involves send and receive of 2 bytes of frequency reference. i have attached the photos of cx-protocall which was programmed for V7 inverter. i want to add new sequence, send&receive msg for V1000 inverter. so please help me how to write for the v1000 inverter. the data to be transfered for v1000 is same as of v7. but i confused with register addressing. so please help me to modify as required. thanks in advance
1.MODBUS SEQUENCE LIST.jpg 2.SEQUENCE 1.jpg 3.SEND MSG LIST.jpg 4.RECEIVE MSG LIST.jpg 5.MATRIX LIST.jpg
Hello, We are now working on a software to collet the configuration of different PLC brands ,using a third software to backup all the simens...
62
Dear all, I want a communication between pc and fx5u. I am considering SLMP protocol. I think it is well documented. But many of the third party...
127
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
368
I’m working on getting a Parallel Redundancy Protocol PRP system set up in a lab situation. The L73 PLC is in rack 4. 3 io racks are 1,2,3. I...
779
Does anyone have information or documentation regarding the protocol used in Rockwell's Remote IO, and how the physical layer of the network...
957
