Connecting L32 to Plant Network
Karinrinkashi
Nov 2017
Atlanta, GA
40
Hello everyone,
We have an L32 processor on 192.168.1.x subnet and our corporate is now asking us to connect all our machines to their network because they are working on a visualization software for machine performance. All of the other processors that we have are equipped with dual IP except for this one machine which has the older L32 processor which I mentioned above.
The corporate network is on 10.74.193.xxx subnet. I tried using the stratix switch VLAN routing but I could not get the corporate to see the PLC. The corporate is using a CISCO 900 switch on their end where the machine will connect to and they established a Vlan 300 on that switch with a specific port for this machine (again, subnet is 10.74.193.xxx).
Again, the devices at my disposal are the stratix switches and also I have a MOXA 102 NAT device.
Has anyone been able to achieve this and what device did they use? Any technical help will also be much appreciated.
regards,
Karinrinkashi
That Moxa NAT-102 should work very nicely for this purpose.
I can't give you step-by-step directions for setting it up for 1:1 NAT, but can mention that TCP Port 44818 is used by Rockwell Automation for unscheduled communication with ControlLogix / CompactLogix, so you definitely need to allow that port number.
Thank you for the reply. I have setup the 1:1 NAT but the communication was still not working. Maybe that port is the key! Thank you for the direction.
If anyone else has any suggestions, please do post.
One common misstep with setting up NAT is assigning a gateway address to your L32E, which would be the local IP address of your NAT.
For example, if you NAT has an IP address of 192.168.1.254, you need to assign your PLC's gateway address to 192.168.1.254.
30
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
51
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
190
Hi, I want to build a demo station to test devices and programs and I need some help with it. I want to connect GuardLogix, Piltzmulti and...
139
please using the usb can i assign any ip address that i want ?
148
