View Single Post
Old February 2nd, 2016, 07:38 AM   #5
rdrast
United States
rdrast is offline
rdrast's Avatar
For setting "More than one" parameter, try using a structure. And "Direct Reference" tags are especially bad for parameter files, try putting your tags in the tag dictionary instead, referencing the PLC.
Even if the tags in the PLC aren't in a structure, you can still create one using folders in FTView...
Folder: HMI
Folder: HMI\MOP_SPEED
Tags in Folder MOP_SPEED: Current_Val, PB_Increase, PB_Decrease
The parameter file would just be: #1=HMI\MOP_SPEED\
Then the objects in the display are just #1Current_Val, #1PB_Increase, #1PB_Decrease.
There is no {} surrounding the parameter substitution.
__________________
How to ask questions the SMART Way!
Look First, Ask Second!
