Problem with master slave
duckie112
Mar 2012
In a cardboard box
46
I use CPU313C-2DP as master and CPU315-2DP as a slave and theyre connecting with each other with a profibus cable. The software for it that I used is from http://support.automation.siemens.co...ard&viewreg=WW
My only problem is that I cant seem to get the outputs high in the variable table and also the inputs wont show on the variable table as on when I switch them on (sm374 card on slave). So far I don't see anything wrong in my software and setup and used this example.
Also forcing the outputs on the master PLC isn't working. I want to know if theres anything that need to be done first aswell in order to force outputs in a master slave system.
//receiving data
DB14.DBD 0 HEX DW#16#0000FF00
DB14.DBD 4 HEX DW#16#00000000
//sending data
DB15.DBD 0 HEX DW#16#0000FFFF DW#16#0000FFFF
DB15.DBD 4 HEX DW#16#FFFF0000 DW#16#FFFF0000
This is what I get when testing sending and receiving. When I force the values at the sending part it will receive. So I have no clue why I cant force outputs.
This is my project file. I see nothing wrong inside this so I hope I forgot something in order to watch the outputs and inputs and turn them on and off.
I hope I remember this correctly:
In the S7300s DP-adress config tab try this:
For the IO exchange area, use the same byte numbers as the partner S7400 (easier to follow).
Your addresses are in the PI area (<IB/QB128) so you don't need to call SFC's to communicate consistent data areas.
If you want to force the outputs, you have to do it â la this:
L IB_FromTheS7400
T QB_Local
And to send the inputs:
L IB_Local
T QB_ToTheS7400
With a grain of salt
Kalle
L IB_FromTheS7400
T QB_Local
L IB_Local
T QB_ToTheS7400
Kalle
So you mean the byte numbers wich are I100 and O100 and use that for both of them. And that STL code you wrote whats QB_Local then?
I interpret your first post as you want to force some outputs in the S7300 from the S7400. As far as I know, you cannot do this directly, but need a load/transfer instruction. The QB_Local is within the output card of your S7300.
Kalle
Kalle
Ya theyre both s7-300 plcs but even when I want to force on the Master it wont work aswell but I shall look into the QB_Local and see if something happens. Now I know that I forgot some bit in programming in order to force and monitor the values.
Gents, I've an Allen Bradley Kinetix 6000 Sercos servo system with 2 motors on a rigid construction. Both motors have the same gear ratio to the...
2,671
hi to all , i'm trying to do a master and slave system using DP ( HW config as follow ) but when i simulate them i could not read from master...
1,729
Hello I have a Electro-Craft IQ-2000 PDM-30 9101-2003 servo driver. My personality module was corrupted as the drive gives Personality Fault...
1,388
:utoh: Hello, today tryed houres to connecting the micromaster 420 of my kaeser compressor to my laptop with the connection kit (MM4...
1,709
Experts! Need Help In My application i have Siemens CPU 316 WITH APPROX 28 PROFIBUS NODES (including Simovert Master Drive -14N.o.s & IM153 &...
4,811
