HMI Software request for input, Movicon.Next by Progea
mbrockley
Jul 2015
Alberta
Hey Everyone,
I'm looking at all new PC based HMI softwares in an effort to find a good one that will replace our current long standing development software. We are currently using Lookout by National Instruments for a number of new HMI projects, and it has several existing bugs and no plans on putting out any version updates.
Price point is an issue. Some projects we would develop would have a large number of tags (Roughly 5000) and likely 100+ screens. Some software such as Ignition Pro or even Factorytalk look great, but we don't serve an industry that would warrant the cost.
It would also require the ability to have a high level of internal logic. Our current program uses several strategies to perform hundreds of miscellaneous math and internal logic commands.
My question is this: Has anyone used Movicon.Next by the Italian company Progea? By running the demo and taking some initial training it could be a good option that I had not found before and was recently featured as a good new option. I would like to hear if anyone has anything good or bad to say about it as even it's older version (movicon 11.5) does not seem to have a very large online presence or troubleshooting forum/section.
Link to control engineering website where it is listed as a 2017 award finalist.
Controleng.com/2017awards
Thanks in advance 🍻
I've done several projects with 11.5 and have had a few hours exploring Next, which was enough to give me the confidence to quote a new project using it.
As with any software, you will always find things it doesn't do as well as others and things that it does better than others, what I will say, their support is very good. If they don't have an existing example of somthing you need already in their library, they'll write one for you.
I have used Movicon 11.5 and it's brilliant, however did find the drivers a bit of a task so used kepware as I/O drivers using OPC the software is easy to use the basic scripts are certainly very powerful and without any prior knowledge had it running in no time it's cost effective. I had a scada system connected to a range of different makes of plc's (used kepware manufacturing suite) I would recommend it. as for the basic, I had to do a lot of work in collecting recipes from an existing SQL database, converting the data i.e. floating point etc. and downloading it to the plc's and it worked a treat
Hi friends I need to download a project to a old Uniop panel model EK12 I have readed that i need old Designer software Has somebody a link...
5,886
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
144
I HAVE SMART TOUCH MS-60T-Pe MITSUBISHI HMI BUT I CANT FIND A SOFTWARE TO EDITE AND DOWNLOAD A PROGRAM IN IT.......CAN ANYONE HELP PLEASE!
59
Hello, I'm working on a machine retrofit project, and am looking for recommendations for HMI/SCADA software. I've used C-More and Horner HMIs...
1,894
Looking for advice/experience with PC based HMI software? We are starting to put a PC in our control systems. I would like to use the monitor as...
28
9,113
