Red Lion HMI Crimson 2.0 String Problem
JuanPLC74
Feb 2017
Houston
23
I have a Red Lion G310 that im programming with Crimson 2.0
I have a internal string Tag that needs to be retentive.
I have a string text with data entry with this variable as tag.
When I click on it and the keyboard pops up, I enter a value, say "Hello".
The string immediately goes crazy, and start showing labels from my screen.
I have some labels that say for example part number, save, load, etc..
and this string starts sort of iterating among them.. at some point the HMI stops and gives me some Guru Meditation code, but it is always different.
Could the HMI have problems? or what could it be?
regards/
I would first try updating the firmware in your unit. You can do that by installing the newest version of Crimson 2 (build 578). See if the problem goes away. If not you should call Red Lion support.
I have never seen a problem like the one you're describing. I suppose it's possible that if your program has some complicated buggy scripting associated with the data entry, it could cause the unit to go crazy and crash. But that seems unlikely.
Do you know where I can get the firmware? .. i am not experienced with red lion, this is sort of a one ff project.
After you update the Crimson software on your PC, they next time you try to download a project it will automatically update the firmware.
I would highly recommend upgrading to Crimson 3 if your unit supports it (older G310's don't).
http://www.redlion.net/crimson-30
I am having issues getting a Red Lion HMI and Micro830 controller to communicate. I am using the cable here to connect the controller to the RS232...
117
Hi I need to send a null command down a comms port. But in the crimson software when i used /x00 it coming back "Cannot use null character is...
420
Hi Everyone, I am hoping a Red Lion Expert can point me in the right direction. I am experimenting with data logging on a CR3000 10" screen...
602
I have a Red Lion G09 scanning 8 Invertek P2 VFDs via modbus RTU - I've setup necessary comms and tags and all works well. I have a 'Settings'...
1,870
Has anyone ever replaced a touch screen on a legacy Red Lion G3 series HMI?
1,452
