OT: Machine
Pressurize with water until the clear housing cracks. Build a jig so it will crack or explode the center, leaving only the three barbed pieces.
Jig is two halves, with rubber pads at ends to seal to barbed portion. Water exit port in center. Pre-scribe to dictate breakage point.
It may take quite a bit of pressure to do it, and exiting water with hard plastic shrapnel will be dangerous.
74
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
89
Hello, I am still new to PLC programming and I just got this job two year out of school so I don’t remember much. I was given a task were I have...
165
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
100
Hi all, I would like to replicate my PC onto a virtual machine so I could use it on a different laptop when I'm on site. I have never created a...
243
