Need a program created in CCW Developer Edition with UDTs
Ajility
May 2022
Tampa, FL
Hi everyone,
I'm looking for a sample program that has some UDTs defined in it for the MicroLogix platform.
To create them, you need to have the developer edition of Connected Components Workbench (I think v20.1).
Its pretty expensive - if you have a copy on hand, I'd appreciate the help.
I'm hoping to use this program to do some testing & help support an open-source Python library. You can find out more about that library here:
https://github.com/ottowayi/pycomm3
Sam
Welcome to the forum!
Do you mean Micro800, not MicroLogix? I am pretty sure the MicroLogix platform does not have UDTs.
_
@drbitboy I do mean Micro800 series. I'm mainly interfacing with ControlLogix and don't know much about the other RA platforms.
Thank you
Sam
Thank you
Sam
The problem is, having a copy of the software isn't enough. You need the license. It's the license that unlocks the features.
I was hoping the program could be run with the Micro800 simulator, but I wouldn't be able to make changes to the UDTs
I'll guess you've already been through this?
https://www.youtube.com/watch?v=gOtodm8QKL0
BTW, your pylogix library is kick ***, thank you for creating it
You could probably test with some pre-defined data types like LCD_REM or MODULE_INFO. However, here's a project with a few custom data types defined. There are no programs created, just a few data types. This was created in CCW12 for a Micro820, 2080-LC20-20QWB V10. I could do a different controller or some particular structures if needed. My Developer Edition is only 12 at this time.
The types I created end with "UDT". Make a variable and scroll through the available types to find them. Capitalization of BOOL vs Bool is different in TopLevelMix and AnotherMixed. I experimented a bit and didn't clean up completely. I found that "CAPS" and "caps" cannot coexist as different elements of a UDT for a duplicate name.
Names of created types:
MotorUDT
TopLevelMixUDT includes SubLevelMixUDT
AnotherMixedUDT
DoubleDintUDT
StringSizesUDT
105
195
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
345
I will be designing an automated hydrostatic system. The system on paper works like this, a plc like the click will get information from an hmi...
227
43,478
Hello. I am working on a PLC program that needs to check input 1 after timer two is complete to see if a valve can close or not. Below is the flow...
2,847
