Importing Tags from RSlogix5000 to factorytalk view ME
rigicon
Aug 2009
kent
415
Hi everyone. I just got the new factorytalk view ME V5 software.
I exported the Rs logix5000 tags inti a CSV file. In factorytalk I tried to import but it must be in a .med format. Huh
Does anyone know how to get the tags into factorytalk view ME please? :unsure:
No need to import the tags. Read the manual on direct referencing.
You can tell the object on the screen to look at the tag in the PLC direct.
You do not need to run a tag database in the Panelview.
Regards Alan Case
Alan looks like that will only work if you are online, Thanks but the machine is 30min away getting built. Is there any other way.
If you tell it where your offline files (PLC logix file)are on your hard drive you can direct reference them, then when the real PLC is there the PV will automatically look at them instead of the offline file.
Regards Alan Case
[FONT=Arial, sans-serif]A123237175 - Using an RSLogix5000 .ACD file for offline browsing[/FONT]​
Look for this tech note application doc on the aB web site.
It will walk you through the entire setup.
Regards Alan Case
Alan is right.
The ACD file MUST be on your local machine not a network drive, etc.
你好,Failed to import the file, "name.L5X". The specified L5X file is not targeted for this import context.我怎么处理?
Smoke I don't think you understand the problem mate. Maybe you haven't read the whole forum.
Hi! I am struck at this point to import 1000 tags from RSLogix5000 to Factory Talk View Studio. When I choose the factory talk view CSV file I...
21,967
I cannot seem to find a solution as to how to import I/O tags from RSLogix onto C-more. Bits and counters populate just fine, but there is no I/O...
1,343
Good afternoon, I am new to programming the PanelView series from AB and need some help with getting my tags to work on the HMI created by OEM. I...
2,034
How can you import tags into Citect from Unity and Rslogix5000? It seems ridiculous for a SCADA software made by schneider cant bring in a .xvm/...
1,143
Hi, Ive had this issue with vijeo designer for a while where every time you do a complete rebuild of the plc program in unity pro you would need...
1,570
