What are:Single-Rotation and Pole-Changing motors?
kalabdel
Feb 2015
Ontario
1,108
Hello everyone,
In the attached motor wiring there are three different types of motors shown, being: 1-Single-rotation motors, Pole-Changing motors and Dual-Voltage motors. Dual voltage I understand, the other two I don't.
Single rotation means I can not change the motor direction of rotation by switching two of the phases?
Also in the wrining shwon isn't the single-rotaion motor also dual voltage Wye and Delta?
Pole-Changing changes the motor speed? How does that work?
Edit:
One more question, what is temperature monitoring or rather how is it implemented in the motor? There's a small terminal block in the junction box that is marked R1 and R2 where do they connect to inside the motor and how are they used in c control circuit?
Kal
Single rotation motor, from what I can see on that drawing is just a normal 3 phase squirrel cage motor. You can change the direction by swapping 2 phases.
Pole changing motors, from what it looks like and what I've worked on before, dependent on how you wire the motor at it's terminals dictated how many poles the winding have. So effectively its a duel speed motor.
R1 and R2 will be wired to some form of thermistor embedded in the motor winding's. Wire to a thermistor protection relay, this will trigger when the motor winding gets hot. If wired into the control circuit properly, it should stop the motor before irreversible winding damage has happened.
Single rotation motors may be referring to a motor with a mechanical device built into it to keep it from rotating in the opposite direction. An example might be a large deep well pump motor with threaded shaft couplings.
single rotation means, only one speed, but two directions,pole changing means the number of poles can be changed, meaning it has more speeds.
dual voltage means it can run on two voltages with same power.
wye is running with only 1/3 of power. .
Thanks shooter. I emailed Lenze tech support and below is what they had to say. Has anyone ever needed to wire a motor so that it can be used with both high and low voltages?
Me:In one of your motor manuals I read a reference to a single rotation motor (see attachment) but I couldn't find a explanation as to what it actually is. I would appreciate a description of the function of a single rotation motor.
Lenze: [FONT=&quot]Single rotation motors means that it can only run off low (208/230/265V) OR high voltage (400/480V) at a time. To change between low and high voltage, you will have to change the dog bones bridges in the terminal block connection as shown in the diagram in the attached document.
Me: [/FONT]
Thanks. These are the motors I'm familiar with but I take it that means that there are motors that can be wired to be used for high and low voltages? Do you have a manual or product catalogue of those motors?
Lenze:[FONT=&quot] Lenze only offer single rotation motors in our current portfolio. We do not offer pole changing motors or dual voltage motors anymore.[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot][/FONT]
I suspect that demand for dual speed/dual voltage motors is dwindling rapidly these days. There's quite a lot of control circuitry involved in making one work, and with the price of VSD's getting ever lower, there's probably very few applications where it's worth the effort.
That's true - probably one application where they'll hold onto relevance for a while longer.
Reduced voltage
Lenze: [FONT=&quot]Single rotation motors means that it can only run off low (208/230/265V) OR high voltage (400/480V) at a time. To change between low and high voltage, you will have to change the dog bones bridges in the terminal block connection as shown in the diagram in the attached document.[/FONT]
[FONT=&quot]Me: [/FONT]
The dual voltage motor is Wye/delta reduced voltage starting motor. It uses wye connections for starting then switchs over to delta connection for running
A normal dual voltage has 6 windings, instead of 3 so it just has more connections.
And yes there are also motors that run with only 3 windings, however this is not really dual voltage as the voltage must be root 3
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
27
I am converting a SLC 500 to a Compact Logix. I plan on using a Compact Logix 5380 with conversion Kit. The problem is that the analog input cards...
142
Hello, friends, I am trying to upgrade a system that uses an Onrom incremental encoder (E6B2-CWZ6C) connected to a Danfoss VFD (FC360), but now...
266
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
166
What would happen if you ran a 60Hz Single Phase Motor on 50Hz supply?
514
