Tag issue in Panel view 600 T6T configured for micrologix 1400
analyzer tech
Jan 2015
baytown, texas
I an new to this:
I am trying to finish a project. Here is the
tagname Data type Address Controller
PUMPA_XS Boolean N7:1/0 PLC-1
My Question: What does the N7:1/0 mean and address. Iam not sure what the / does for the address.
thank You
Welcome to the forum!
N7:1 is a 16 bit integer. By specifying N7:1/0, you're specifying bit 0 of this integer.
The hint is in the fact that your tag is defined as a Boolean - so, obviously, you need to specify one bit, be that a single bit out on it's own, or a single bit within a larger structure like an integer.
The N registers are Interger registers (16 bit). The address of N7:1/0 means that you are looking at bit 0 of the first word.
Here is how it breaks out:
N7 = file 7 is a Interger data type
:1 = second Interger word. 0 is the first word
/0 = bit zero of the word
Hope this helps.
Edit: ASF wins the typing race ��
Polish it off Professors!...
The ":" is a word delimiter
The "/" is a bit delimiter
There, now I can do my days work.
Regards,
George
Hi, I have an issue accessing tags in 3 of my plcs'. When I go to select a tag there is no folder drop down as can be seen in the photo. Any...
63
Hello all. I have a feeling I am going to shame myself with this question but I can't resolve it and can't figure it out......probably making it...
1,001
I have not used Logix beyond V24 for a few years (production environment) until recently. I have 3x L84ES in a new project. We are sending...
787
Hi All, I have a new 5 PLC system. Each has the same firmware revision. Each PLC has the same User Defined UDT for Safety Tags. PLC1 reads from...
2,006
Hello, we have a project using FTView SE 10 (Network Distributed). We configured PLC and HMI in an existing application, and the communication...
1,066
