kinetix 300 "start homing on enable"
oystek
Apr 2016
Adelaide
I have been using an AB Ultra 3000 servo drive to control a servo motor and it was setup to "home on enable". I have had to change to a Kinetix 300 drive and it seems like there is no way to have it carry out the same home function when it is turned on. Can anyone help me please.
Thanks for your input. Seems that the Kinetix 300 has a permanent memory of where home is once it is set. Not so clear in the notes. Spent all day sorting this and some other issues. Looks like I am rolling.🍺 Thanks again.
Oystek
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
136
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
201
Hello. I have a few machines that use Kinetix 300 (each machine has two drives). Both drives on one of the machine keep losing IP address. They...
92
Hello, We have had a machine running for the last 10 years. It has 2 x Kinetix 300 drives. Around a year ago, one of the drives failed. We were...
419
Hello, I have a die punch machine with servo motor for material feeding. I'm using Kinetix 5300 to control the feeding system. Every recipe have...
511
