PACSystem Rx3i Time and Date
mikewest
Oct 2013
Drifting
I must have missed something in the manuals / online help but I can't figure out how to change the Controller time and date on a GE PACSystems Rx3i controller that I have inherited the maintenance and support of.
I have read something about syncing to a time server but this baby has no external connection and it has a date set for September 2000 which is just slightly wrong. I don't need the time to be really accurate as it is only for internal diagnostics. It has thrown a couple of faults over the last couple of months and it is a pain to try and calculate back to the actual fault generation time. TBH this is one of the lesser problems I am having with the this whole system but it is really bugging me.
I hope someone can point me in the right direction.
Go online with the controller.
Right-click on the controller, then click on "Show Status".
In the new window, click the Date tab.
You can sync to your PC or set a time manually.
Hi I'm doing a boring manual conversion of a ladder program and have a question regarding how the timers work on this system. I don't have this...
2,415
Hello All- I'm trying to re-structure my PLC code (in LD). The current code has blocks contain different type of memory areas (%AI, %AQ, %I, %M...
2,402
A question to those unfortunate souls that have had to work with GE Fanuc PLCs... I'm using an RX3i. How can I get the time from the PLC? I...
3,114
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
80
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
948
