Importing comments in Studio 5000
Jim G.
Nov 2007
Georgia
187
We recently upgraded an A-B processor to firmware V33. I went to open the program the other day and the program comes up but the comments are missing. Have been trying to import the comments ever since but, after the import runs for several hours, it stops and kicks out the following error. See attachment.
How do I recover my comments?
dmroeder would probably tell you to export to L5K and create a new project from that and see what happens. I would agree with him. Then try to import the comments again.
hmm, that does sound like something I might say. The new phrase I'm trying to make stick is give your ACD an enema.
Searching the knowledge base, that particular hex error code is given for a LOT of different issues.
WAG, if you go to the View dropdown menu, make sure the "watch" window is closed (uncheck it). That watch window has caused some strange crashes. Along with that, they recommend uninstalling .NET framework 4.7.1.
Hi, I have been using V19 and V20 RSLogix PLCs for a while now and have always been able to import tag comments to an ACD file offline then, go...
3,205
Hello, I am working with Studio 5000 and due to uploading a controller with a file that was not updated, have lost the rung comments. Oddly...
2,427
Hi guys. I imported tags from RS Studio 5000 project as offline tags, but there are no comments (descriptions) of tags in Factory talk. Is it...
2,263
Hey everyone, I'm working on a program for a SLC 5/05 controller using RSLogix500 v. 7.30.10 (CPR 9). We have a number of the same little...
14,846
As the title says, I'm trying to figure out a way to import and export recipe files from an external CF card to a USB drive and vice versa. I've...
483
